NW Ohio | We are running the JD 2600 display with autotrac. I can mark the "switch" box for manual, and it shades the area where we drive when the drill is not hooked up. I hooked up the seeder that has the harness for running with a brown box. Now when the display comes on, I can use the brown box feature in the 2600 display. However, it will not let me change the "switch" box in the implement set-up to work with the whisker switch on the drill. The box is lightly shaded grey and reads "automatic" (I think?) It will not let me change it to the whisker or manual settings. If I unhook the harness, I can set it for the whisker switch, but when I plug the harness back in, it goes to the greyed box.
Can I use the brown box features and GS2 features of the system at the same time in the same display? I sat my home pages to go between the brown box view and guidance views. What do I need to do to make the whisker switch work properly? Connections are good into the wiring harness. TIA | |
