Search Forums | Classifieds (26) | Skins | Language
EZ steer/guide settings with Tracks. CAT 55
otteb
Posted 8/26/2013 22:44 (#3291371)
Subject: EZ steer/guide settings with Tracks. CAT 55
SC Kansas
Installing an EZ steer system on a 97 CAT 55. Couple questions. What do I enter for and axle "offset"? From the center of the rear axle or the pivot point of the track? I've heard different things. Should I mount the antennae towards the front of the cab or at the pivot point of the tractor or tracks? Should the degree of turn be larger or smaller on a tracked vehicle? Does anyone wish to share their settings?Does the setup wizard even list an option for a tracked tractor? Can you enter it as a swather? Any and all tips and insights will be greatly appreciated. TIA
