Search Forums | Classifieds (22) | Skins | Language
Pro 600/700 Coverage Map, Work Control
chedv
Posted 8/22/2013 06:35 (#3281509)
Subject: Pro 600/700 Coverage Map, Work Control
SE IL
When planting beans (1240) this fall with our Magnum 290 and Pro 700, whenever I would lower the planter, the coverage map was correct. It was "painting green". Whenever I unhook the planter and put a disk or more importantly, drilling wheat this fall, I can't get the coverage to work right with the number one hydraulic lever. When I lower it, it will paint green, and then it might stop. It is very flaky and cuts in and out. Is there a trigger point where I can set this to stay painting green and logging acres?
Right now I'm using "generic tractor". When I set work control to "on" it paints green all of the time. However, I don't' want the turns and end-rows to count until I actually do them. If it would work just like the planter, it would be great.
Thanks
