Search Forums | Classifieds (58) | Skins | Language
Nitro 5275/NH SP275/AgLeader questions...
beiswanger
Posted 7/27/2013 08:33 (#3231926)
Subject: Nitro 5275/NH SP275/AgLeader questions...
ECIN
We have a NH SP275 front boom run by an Insight/372/Autopilot combination and have two lingering questions that our dealer has not yet been able to figure out:
1. Is it possible to get the spray system "dump valve" to work correctly in conjunction with the boom valves (open the dump valve when the master switch is off)? Now, the only time the dump valve will open is when all of the boom section switches in the handle are MANUALLY turned off. We have tried swapping the AL liquid module, changing Aux valve settings in the Insight, and running a signal wire directly to the valve without any success.
2. Is it possible to get the steering engage switch in the handle to work with the Insight/Autopilot? We have also tried (unsuccessfully) pinning a footswitch directly into the factory NavII harness.
