South Central Kansas | I have a JD 7730 with the Trimble 750, the tractor is plumbed internally so no motor on the steering wheel. Whenever I engage the ez steer for the first few times each day, the steering waggles. In warmer weather, it clears up in 10-15 minutes, in colder weather, it take a little longer. If you stop for lunch on a hot day, it will do it again when you fire up.
The AB line is always straight from one end of the field to the other, but the waggling is fairly quick and is really annoying.
Dealer has NO idea what is causing the problem. I have adjusted aggressiveness to no avail. It works perfectly other than that. I am running RTK as well.
Thanks in advance. | |
