South Africa | Hi. I have installed 3 autopilots on MX 220 and MX 270 tractors. When doing the calibration, I noticed that when the autopilot turns the vehicle to the right, the steering wheel turns to the left, and when the autopilot turns to the left, the steering wheel turns to the right.
The calibration can be completed and no manual override is detected when this happens. I took the tractors to the field and it will engage on the line and work 100%, but the steering wheel keep turning in the opposite direction.
Is there anything I can do to fix this? I tried to change the A and B hoses with no effect, everything is like the manual. When the autopilot is engaged, I can also grab the steering wheel and nothing will happen, autopilot will stay engaged until I turn the steering wheel. All three are full hydraulic installs.
Any suggestions? | |
