Search Forums | Classifieds (58) | Skins | Language
Stafire 3000
Glenn Dye
Posted 7/22/2013 22:42 (#3224015)
Subject: Stafire 3000
Appomattox/Fredericksburg, VA
Has anyone else had problems recently running adaptive curves? I run those while planting my end rows but here recently, the line is on one minute then way off the next. I drop the marker just in case the trees interfere with the GPS. Running SF1 so yes I know there is drift in there. But pass to pass had always been sufficient until now. Still does fine once I set my straight track AB line. Changed the receiver height to 1 inch to see if it would help but didn't. Have recalibrated the TCM but didn't change anything. Software is up to date. Did notice however that the Yaw Rate does not change but a degree or two when on steep slopes. Could the TCM have gone to lunch? Never heard of any problems with the receivers but funnier things have happened. Receiver is still under warranty. Curious if anyone else has seen this recently.
