Search Forums | Classifieds (201) | Skins | Language
4420 CaseIH sprayer over applying
Cashgrabber
Posted 7/15/2013 00:19 (#3209201)
Subject: 4420 CaseIH sprayer over applying
Southwest Ontario
Using aim command with pro 700 and now I can't get sprayer to put out right volume. It's over applying 10% or 100 gals per fill up. Checked flow meter #, did a distance cal using GPS, checked boom config, for 120ft, boom, running 60psi with water. I have to figure that the tank is only 1100gals on a fill up then work my acres and rates from that number or I will run out with 100 gals left showing in my tank on the monitor. What should I check next?
