![](/profile/get-photo.asp?memberid=21169&type=profile&rnd=217)
| I asked this in the machinery section, but figured I would ask it here as well. This spring I was putting in some tile and hit a very wet spot at the end of the run. I only had about a 100 ft left to go and I was down about 3 ft when I lost traction. I figured I could lift up a bit and finish the run, so I stopped the run on intellislope and manually lifted up a bit until I could pull it, then went back to auto install for the rest of the run. It told me at that point that I had to be down 4 ft to complete the run even though it was almost completely flat that last 100 ft. The tractor had spun down in the mud quite a ways. Could that have been the cause or am I missing something?
I ended up just cutting the tile line short and not going any farther because I did not want to mess something up. I figured it was better to go back and resurvey and install the rest from dryer ground instead of trying to continue on in the mud with those strange parameters.
Does anyone have any idea what was going on there? | |
