Search Forums | Classifieds (3) | Skins | Language
Kubota RTV 900 run hydraulic spray solution pump?
jdaggie
Posted 6/8/2013 16:55 (#3144282)
Subject: Kubota RTV 900 run hydraulic spray solution pump?
Kings County, California
With the optional hydraulic package, can you run a hyd solution pump for a sprayer.  I thought it would be better/less expensive then a honda gas motor setup.
Also, how does this unit compare to the John Deere Gator 855D?
Thank you for your help,
JD
