NW Saskatchewan | Hi all, just wondering what anyone with Bourgault air drills are using to mount the many controls required to run them in the cab.We bought a 3710 coulter drill and not impressed with all the junk in the cab.....monitor, Main clutch switch, drill control. rate control and calibration clucth switch box.
In New Holland T9040 have them bolted down to a 2 in. angle iron which in turn I clamped to the factory monitor bar. Doesn't look too bad but still cluttered and kind of fills up the RH side window.What has everyone else done, or does Bourgault make something specific.
Coming from a Flex-Coil so not used to all the extra wire harnesses either...can't help but think Bourgault should enter the modern age and use micro-pin connectors or something....with getting stuck pretty regular this spring and having to unhook it got to be a nightmare after the first few times, there's like 5 or so harnesses at the back of the tractor to disconnect.... | |
