Search Forums | Classifieds (198) | Skins | Language
Hypothetical Hybrid logging and population
hilltamer
Posted 6/1/2013 22:03 (#3132259)
Subject: Hypothetical Hybrid logging and population
Lets say a guy has a mechanical driven planter and wanted to keep it that way so if worst came to worse he can plant instead of being totally frustrated with tech. But would like to add some of the features of an integra FM1000 or 2630.
Can hybrid logging be done with out any special modules and such? Afterall it would just be a coverage map that potentially each half of the planter has a different hyrid.
Can said coverage map have a manually entered population that records this for future reference?
Could a Duo rate clutch system be used to vary the rate for Hill vs bottom rate situations and also record where it change from high to low on the map much like a coverage map for population? would this be the point that a seed tube amonitoring module is needed?
Thanks for any replies
