Search Forums | Classifieds (158) | Skins | Language
Agleader Liquid control to replace Raven 450
superfarmer
Posted 5/19/2013 19:34 (#3106006)
Subject: Agleader Liquid control to replace Raven 450
Eastern Ontario
I'm replacing my Raven 450 with my Agleader Integra. What wire harness do I need from the liquid control module to control my boom sections (3 pin weatherpack), control valve (2 pin flat), flow meter (3 pin, can't think of the name, but raven uses them on all flow meters), and a pressure transducer (same style connector as flowmeter)? I'd also like to be able to control 2 auxiliary bypass valves, where to they tie in? Agleader's catalog is not clear as to what each harness does. Thanks.
edit: conxall is the connector on the flowmeter and transducer, or at least that's what sensor 1 calls them.
Edited by superfarmer 5/19/2013 19:38
