Hamilton, OH/ Browning, MO | I posted a question last night about being able to set up guidance in an integra to spray with. Well today I hooked the integra from the combine into the sprayer in place of the insight. It seems as though I need a GPS reciever that will do 5 Hz, and the one I have is only 1Hz. Everything thing else seemed to be fine, but I didn't try to spray since it was raining again. Is this just as simple as buying a different GPS reciever? I did notice that in the GPS/ Guidance Setup screen, in the middle under GPS that I didn't have anything in the Diferrential Source space. The manual says I should have WAAS if using manual guidance. But I was getting a signal, just only 1 Hz. Will this be grayed out until I get a stronger reciever?
Thanks, Adam |
