Search Forums | Classifieds (159) | Skins | Language
Update on Raven control valve speed
hf213
Posted 5/17/2013 16:58 (#3102371)
Subject: Update on Raven control valve speed
THANKS to all who responded,
I finally got a chance to burndown some cereal rye, and I ended up setting the valve cal to 2323, and setting a low limit to 10. I still need to tweak a little more yet, but these ideas, DEFINITELY HELPED.
Also I had found I had some plugging issues with my strainers and agitiation valves from my Harness X tra ( never had issues here at all before using this herbicide ) .....that really seamed gummy and rubbery this year for some reason.....anyhow thoroughly cleaned out the sprayer before going back to beans, I have just about every line connected by cam locks and does that ever work slick to check and clean ! and all is well again.
I'm thinking of bumping the low limit up to 11 or 12.... My flow volume number was like 15 - 16 at my target rate and speed....
but I am on the right track !!!!!
THANKS AGAIN ALL YOU GUYS !!!!!!!!! I owe ya big time !
