Search Forums | Classifieds (82) | Skins | Language
Pro 600 as a light bar in a Puma 130
Chains77
Posted 5/15/2013 07:49 (#3098787)
Subject: Pro 600 as a light bar in a Puma 130
I want to use a Pro 600 as a lightbar in a non-AFS Puma.
I've got a 252 receiver installed on the roof, the cable from Case to power the receiver and send a signal to the serial port on the 600. I have a cable to the 600 supplying 12V (both keyed and live) and a ground.
I am trying to use WAAS
What settings do I have to change to get the lightbar to work properly? Right now the line jumps around from right on to +/- 12" - 20" while driving slow in the yard. Worse in the field.
Do I have to change settings in the RDI screen?
Also, the re-mark swath doesn't allow me to 'set to current'.
I was hoping to utilize this command to keep it simple for our hired hand.
