Search Forums | Classifieds (44) | Skins | Language
Sure stop Clutch problems
tkwfarms
Posted 5/10/2013 21:43 (#3091803)
Subject: Sure stop Clutch problems
Shubert, NE
I have a integra which monitors a 2600 kinze planter and runs sure stop clutches on the back 12 split every 2 rows. Today on and off I would have one section randomly shut off going through the field and if I stopped and raised and lowered the planter a few times it would figure it out and work for a while. This was not just one section all 6 did it at some point today. When the shut off going through the field the monitor doesnt show anything planting, however when the stick on when they should be off they are mapping on already covered ground but the monitor shows its not planting. Do I just have a bad connection somewhere or do I have a different problem? It works fine otherwise its just aggrevating when it does it. It is also current on all updates. Thanks!
