Search Forums | Classifieds (45) | Skins | Language
Envizio Accurow/Accuboom question.
jason.karels
Posted 5/10/2013 09:30 (#3090674)
Subject: Envizio Accurow/Accuboom question.
At the tech school I teach at, we have a "super modified" JD 7000 that is using an Envizio Pro to run the planter meters and liquid fertilizer pump. I set the drives to work via the master switch.
The planter drives seem to be working fine, but the fert. pump will not turn on, whether I flip the Accuboom toggle button to On/Auto/Off.
If I switch from using the master switch to the on-screen arrow, then the fert. pump will work.
The planter has the planter node and two product nodes. Right now, I am using one node for fertilizer application. The other is not being used at the moment.
The nodes and the Envizio are updated.
I am assuming I am missing something simple, but for the life of me I can't see it.
Thank You for the help.
Jason
P.S. I posted earlier about getting Starfire signal to the Raven. It was an issue of the cable not plug-in ready. I had to re-do John Deere cables to fit into John Deere cables
Thank you for the assistance there!
