| I have a 2600 display with greenstar rate controller controlling the flow and ball valves on a pull type sprayer. The problem I am running into is coverage shows on the screen when I spray the end rows but the sections will not shut off when I overlap. All software is up to date and the flow control works fine. I have the swath control activated and I can manually turn on and off the sections with the section test function. In the swath control diagnostics page it shuts all of the sections off (reads 6 - speed to low) when I stop so that is working fine as well. I am just wondering if anyone has ran into this problem before and if so what you did to correct it. | |
