NW Minnesota | I was out driving the gravel roads with my mx 245 to warm up the differential and planetaries so I could change out the grease and decided to try the ez steer to make sure it was working ok for spring and after I made my line I engaged it and it shook the whole steering column and after maybe 30 seconds it disengaged by itself, (yes I did slow down to do this) Any ideas? Thanks in advance! I tried several times and also went through the initial setup again and also tried lowering aggressiveness and increasing wheelbase but it doesn't help.
Edited by prttimefarmer 4/21/2013 11:00
