NW Ohio | Trying to figure out the new-to-us 2600 display. The planter has the xp harness and air bags. When the planter is raised, there is still a number value showing in the down pressure area of the screen. I figured it should be 0. When I adjust the down pressure on the screen, I can't go down to 0 either. How do you reset these values to start at 0? I found in the manual that it says to re-zero it if it does this, but I haven't found a place that tells me how. I'll be looking at it again tomorrow. TIA | |
