Manila, Ar | I was finishing spraying the other day when the engine blew a large puff of black smoke and shutdown and would not restart. I called dealer and they say valves are bad to fail. Does valves failing cause the engine to completely shutdown and with no noise while trying to restart? I have enough experience with older diesel engines to know that if one cylinder has failed it should run on the other 5, but I have no experience with the newer engines, and the computers that run them. | |
