![](/profile/get-photo.asp?memberid=26689&type=profile&rnd=613) Manitoba | The pto in our tractor won't stop spinning, nor will it fully engage. I can't push the lever far enough forward to lock it on, the lever is in the off position but the pto still turns slowly. I can't push the lever back into the brake position either. I've checked there isn't anything binding the linkage, it must be something in the hydraulic block that activates the pto on right side of tractor. Anybody had this problem in their deutz or white (same rear end), or would you know what is causing it and if it is a big or small fix. | |
