Search Forums | Classifieds (135) | Skins | Language
John Deere 3020
twocyler
Posted 7/17/2012 12:22 (#2490473)
Subject: John Deere 3020
After carrying a heavy bale with the 3-point hitch the hydraulics heat up and you loose lift capability. Consideration is being made to remove & go into the rockshaft valve assembly looking for a blown packing, scoring, crack or etc.
The main pump standby pressure has been checked at 2200 psi.
What ideas or diagnostic tests do you suggest or what packings / seals to more specifically look for?
Thanks.....
