Great Southern, Western Australia | Thanks to AT for the advice last time. Thought we had the tracks aligned pretty good. All of a sudden one is rubbing again, we are not sure what could have changed? And we are out of adjustment on the front idler wheel. Strange thing is that it is actually rubbing on the drive wheel more so than anywhere else. It is not perfect at the front midwheels, but there is a gap. We noticed on the first attempt that the hardbar spacing is 8-10mm different to the rear axle. If the differenc ewas effectively creating a 'toe-in' could this cause the symptoms we have where it is actually rubbing worst on the drive wheel? |
