Gap on Tri-Lobe Conditioners/ 995
crabby
Posted 5/3/2012 22:29 (#2367660)
Subject: Gap on Tri-Lobe Conditioners/ 995
SW Missouri
Started mowing grass hay today and it doesn't seem to be doing much conditioning. This is my first experience with the Tri-Lobe setup but there appears to be to much gap between the rolls. Looks as though they have extra spacers on the adjustment bolts. How tight do you set them? I was thinking you are supposed to run them closer than regular steel rolls. As usual, book isn't much help.
