Was cutting hay today about 3hrs into it and all of a sudden the pto just quit. JD tech said to check end of pto 1000 end that pushes in a switch to tell the tractor its in 540 if its worn need to replace OR weld it up an grind flat it should work.What do you guys think I think it may need to go to the shop any ideas would be appreciated.
