Dayton, IA | First year with Raven Sidekick. Found out fast the tank only holds 25 gallons. Have been using it for roundup but that is just enough for one sprayer load. We have to fill it up every time we fill the sprayer so there is really no advantage to using it, it would be easier to just pump the roundup into the mix-eze with the other chemicals and not have to fill the Sidekick seperate. What is the best way to increase capacity, do we add on another tank or is there a bigger tank that will fit on where the small one does now. How have you delt with the sidekick tank size?
Thanks,
A.J. | |
