Search Forums | Classifieds (120) | Skins | Language
Deere 1770NT piston pump
GJO
Posted 4/26/2012 22:17 (#2355426)
Subject: Deere 1770NT piston pump
Can't get my piston pump to apply correct amount of starter fertilizer. I have the low pressure setup and in the past I set it for 12 gallons which is like 3.25 on the wheel pointer. Set it there and I only got about 6 gallons on. Set pointer to 4.5 and got just a little over 7 gallons on. Check screen and its clean, had pump apart and I checked it personally and seems fine inside, valves and such. Anything I am missing? very dissapointing when in the past it was always right on, if you set it for 12 gallons you got 12 gallons, not this spring so far! Thanks, jake
