Search Forums | Classifieds (64) | Skins | Language
NH TG255 Fault codes
lee95
Posted 4/24/2012 20:10 (#2352084)
Subject: NH TG255 Fault codes
Central Illinois
Tractor dies when idling everything on the corner post goes dead tractor will crank but not start I have been messing with fuses and connections and after awhile all of sudden the corner post will light up and tractor will start it might run a couple of minutes or several hours and I can't really connect it to anything that I wiggled. Sometimes I can get to restart in a few minutes sometimes it takes a half hour so I don't know if maybe it would be a circuit breaker? the last fault code is 12031 and also 12011 shows up alot if anyone knows what they are Thank You
