Search Forums | Classifieds (2) | Skins | Language
IH 5488 and 7200 JD vac planter and monitor questions
Pete1468
Posted 4/22/2012 11:31 (#2348384)
Subject: IH 5488 and 7200 JD vac planter and monitor questions
Norhtwest Iowa
What is the normal inches of vaccum you can run with this set up? The most I've seen so far is 7 with seed in it. I've got the planter valve backed all the way out and the tractor hydraulics maxed out. Oil return is going to a dump port. It's an 8 row narrow.
I've also got a couple of questions about the monitor, it's a 250 monitor and it says all the rows are failing. I've planted maybe 500 feet. I'm running the monitor without the radar. I'm going to scratch my head for a while longer on this thing. I may take the radar off my 7250 if I need to.
