Search Forums | Classifieds (8) | Skins | Language
4250 v. 4450
mschultz
Posted 4/7/2012 00:49 (#2324729)
Subject: 4250 v. 4450
Oregon
I'm looking at a clean low hour 4250 MFWD. As I recall, the mechanicals of the 42 and 44 are the same. So-as you may be guessing, I'm wondering if I can turn a 42 up to 44 hp ratings. Is the only difference the pump, or are there other specifications in play like piston cooling, rear ends etc?
Thanks.
-Mike
This place also has a 4440 FWA sitting around- pretty clean with easy hours (pulling a small square with its own power plant around) in case anyone on here is crazy about FWA 40 series Deeres...
