| I am planning on installing 6 HID lights on a 7140 magnum. 2 trapeziod in the front, top of cab, 2 traps at the beltline and 2 floods on the top,rear of cab. They are 55 Watt and the lights are 4X6 from Sloan/Speaker. I plan on using relays which will get there signal to turn on from the existing light switch. I understand how a relay works, but that is about it. The lights that I am replacing come on at two different positions of the light switch. The top of cab, front, come on at one setting and the back and beltline come on at another position, so do I need 2 relays to accomplish that? Where is a good place to buy them? Will I have to size them for the several second inrush of current to light them or on normal operating current?
Where would be a good place other than the battteries to tap for the power supply on a 71 series magnum?
Thank you for any suggestions. | |
