Wisconsin | I have a raven rfm 15 i am using on a potato planter and have it at a 90 degree angle vertical and 9you inches away from control valve and boom valve. And they are assembled in this order using raven 2 inch plumbing. My target rate is 2a gallons per acre and i am using a twelve volt hypro pump and inlet lines an outlet lines are 3/4 inch hose. I am having problems with the flowmeter spinning. I am using tips that open at five pounds and pressure at the gauge is about 7 psi. This is a brand new setup? Any suggestions? | |
