North central IL. | we have a sunflower soilfinisher model 6433 and it does not let down to the same depth all the time. it seems that if you raise it up all the way on the ends it will go down to the proper depth, but if you only raise it a little bit then lower it does not go down to the right spot one time to deep and the next time not deep anough.
any thoughts or suggestions would be great. TIA. | |
