adding yield monitoring/mapping to a 9550
OntariOtis
Posted 3/7/2012 17:55 (#2273804)
Subject: adding yield monitoring/mapping to a 9550
Ilderton, Ontario
I have a 2003 9550 combine. It came "prewired" for a JD yield monitor. We are now at a point we would like to start yield mapping.
What is the bare minimum we can use to get to the point of mapping.
I have looked into a PF3000 with gps, but was thinking it would be nice to use the JD wiring harness and not have to cut holes in the clean grain elevator for mass flow and moisture sensors.
I have also looked at a used Insight from a New Holland combine. Would the mass flow and moisture sensor be compatable in my 9550?
Edited by OntariOtis 3/7/2012 18:29
