Posted 3/7/2012 08:31 (#2272988) Subject: Field IQ and Accu-control default speed
Indiana
I seen on the new accu control system which was using a rawson drive, if GPS is lost, there is a setting: Default Speed, that will allow the rawson to continue to run at that speed set. I just wanted to know is that available with a 1000/750 field IQ setup, or is it just in the accu control software. Also, is it only with a rawson or can it be used with a pwm as well?
