Search Forums | Classifieds (121) | Skins | Language
FM 750 guidence lines
Nebraska Sandhiller
Posted 2/20/2012 22:32 (#2241467)
Subject: FM 750 guidence lines
NNW Nebraska
trying to figure out how to start fields.
Most of my fields are pivots, and because the edges are often close to the fence, I plant two rounds with a 12 row planter, then plant the rest of the field straight across.
If I map boarders of the field, can I use that, and nudge to set up a ab line to drive on, from that line.
I have equipment that is 13' wide, 24' wide, 30' wide , and 45' wide. so how do I get lines the correct distance from the edge for each implement?
Or do I map headlands? I have played with mapping boarders, but not yet with headlands.
If I drive the field edge with either the tractor close to the edge, or the atv, what is the best procedure so that when I hook on a implement, I can have a line to drive on that fits that implement?
other than doing it to learn how to do it, would it be a waste of time to do this ahead of time using waas? Will subscribe to omni when it gets time to start working in the fields. Then I understand that omni drifts as well so if I get the edges marked, can I nudge to get to the ab line I need to use. Would I still need to do the edge just as I am ready to work the field, or would omni be better at moving the line?
