Central Kansas | I'm still trying to learn more about the AutoTrac system in this JD tractor (8410T) that I got at the end of last year. Got the "straight track" pretty well figured out and wanted to try the "curve track" mode and on the display, it says that "Auto Trac will not function in this mode"..................same with "Row Finder".
What is the reason for this? Do I need something else as far as equipment or some kind of update?.....................have a StarFire ITC with a Brown box most likely installed in 2006 as far as I can tell.
Thanks | |
