2011 Case Stieger 400 with factory installed steering valve. 2011 John Deere 1770NT with Row Command and the Seed Star XP so it really needs the 2630 to run it. 2630 has SF1 AutoTrac unlock among others. Also have a MojoRTK console and base station. I assume to make this stuff all work together I need the SRK for the Stieger, a JD tractor harness for the Steiger and then I can give the 2630 position information via NMEA. If I want to be able to save AB lines then I will probably need the Mojo3D to be able to manage them efficiently. Does anyone have any ideas for approaching this a better way and does anyone know whether the NMEA out from the MojoRTK will properly supply the 2630? Thanks.
Edited by dpilot83 2/13/2012 14:13
