Search Forums | Classifieds (24) | Skins | Language
Which guidance lines do you guys prefer?
ihman
Posted 2/12/2012 17:05 (#2223428)
Subject: Which guidance lines do you guys prefer?
Bourbon, Indiana
I'm mainly asking for input on my end, I really want to master guiadance throughout the whole field this year and am stumped on what guidance pattern to use on the headlands. I'm using a ez guide 500 w/ez steer and a new to me FMX....My experience is that you can't switch back and froth from one set of ab lines as easily as you can other companies. In the past I've tried to use the headlans mode on my trimbles and sometimes it works sometimes it don't, mainly I forget to hit the button at the right time and that screws it all up. So this year I figured I'd try adaptive curve on the headlands, do one side of the field drive (without planting) to the other side of the field and do those headlands and then start with my AB lines through out the field. Switching from adaptive curve then to ab, then back to adaptive curve then finally ab is time consuming....
Maybe I'm making this to hard but just wanted to see what others have mastered.
thanx
Brad
