Trimble WM Drain Users...
beiswanger
Posted 2/7/2012 10:42 (#2211209)
Subject: Trimble WM Drain Users...
ECIN
We are setting up to survey with WM Drain (v6.01), and I am curious what you are using for your survey point density (our elevation may vary 20 feet within a field, but the hills are moderate slopes)?
Over the past few years, we have run FLII v4., v5+, etc., on the plow and it used the fine, medium, and coarse designations for point density. I felt like the coarse setting (25 ft) was all I could use on a 100+ acre field to keep the FmX from locking up/bogging down while surveying.
Edit: Is it possible to run Autopilot on section lines in v.601, or do we still have to create guidance lines separately? Thanks!
Edited by beiswanger 2/7/2012 11:05
