Missouri | I don't mess with the 500s alot anymore and I know this wasn't possible at one time but does anyone know if you can run RTK signal into a 500 with a 262 and radio instead of unlocking the 500 and buying a sitenet? The reason I ask is I have a guy that already has the 262 and has been running autopilot with an Insight for years. We were thinking about putting a 20/20 on the new planter and instead of putting it and a Insight both in the cab maybe just switch to using the 500 for running the autopilot plus that way you could have free form guidance. If you can import the signal and run the autopilot that way what all cables are required to get the antenna into it? Is it plugged through the octopus cable or a cable running out of the lightbar.
Thanks | |
