Search Forums | Classifieds (205) | Skins | Language
Spreader Control Valve
waterbottle
Posted 1/11/2012 04:02 (#2154966)
Subject: Spreader Control Valve
South Australia
Looking at buying one of these spreaders
http://www.gyral.com.au/ProductRange/SpreadersSilage/BeltSpreaders/...
The spreader has a hydraulic drive belt and spinners and according to the specs for optimum performance it uses 35 litres per minute or 9.4 gallons per minute.
I want to put a PVG valve on the motor that runs the belt so i can so the belt down and speed it up to vary my rates.
Can anyone recommend a valve that can do this running on 12 volt? How much should this valve cost. Factory fit it is quite expensive ($3200) but I think this is because they are buying it through Topcon rather than a hydraulic specialist.
Cheers for your help.
