East Iowa | 2377 with CIH monitor. For some reason it won't show yield above 11-14 bpa and a flow rate above 120. Doesn't matter what C-1 is set at. Distance is correct and counting acres ok. Moisture ok. Flow sensor looks ok and deflector plate is set correctly. It worked great last year and I made no changes.
Could it be the flow sensor gone bad or the box beside the RH cab door?
Any ideas? Thanks.
ps Working on soybeans if it matters. | |
