Kingston,Mi | Use a guage isolator mounted somewhere outside the cab, I have one mounted in the removeable panel on a John Deere sound guard cab, it has a garden hose connection attached on the sprayer side and a hose barb on the inside. Attached a 1/4 or 5/16 hose from it to the spray controller guage and filled with antifreeze solution.
Pressure from sprayer (and spray mixture) press a gainst diaphram and transmit pressure to the antifreeze solution which applies pressure to the guage in the contoller. all the potentially nasty stuff stays outside.
I think I purchased mine at an AGCHEM dealer, Shoup has a kit with the isolator, tubing, connectors and a fill syringe with instructions for $63.30. | |
