Western NY | Check for visible leaks and check to see if fuel pump is pulsing..... We have had a ton of problems this year with gas!!!! I don't know what has changed from last year to this year, but I do know that at least 40-50% of the problems with lawn mowers at the parts counter have been related to fuel. We have a fuel sample set aside in the shop that we filled to about 2 inches in the sample bottle. In said bottle, after a couple days, you can visibly see the ethanol seperated from the gasoline at the top of the sample. If you aren't treating your fuel, start doing so now. All small engines should be treated (fert pumps, weed eaters, push lawn mowers, ride on's, etc.). It is getting to be like Low Sulphur in Diesel.
Danny | |
