Search Forums | Classifieds (23) | Skins | Language
is there any way to override a agleader implement switch
rupert
Posted 4/25/2011 16:10 (#1744089)
Subject: is there any way to override a agleader implement switch
IA
Have a deere 1790 planter with an integra running tru count clutches. It is also ground driven. I used to just spin the wheel enough so corn was coming out all the rows bit now the only way to get it to work is tripping the implement switch at the same time. Agleaders solution to it was to go to a grassy area and put it in the ground until its primed?! That dosent seem right to me. Is there an easy way of overriding the switch on the monitor without unplugging the switch? Thanks
