Search Forums | Classifieds (9) | Skins | Language
GS2 Rate Controller pressure transducer
Radiehl
Posted 4/24/2011 22:25 (#1743005)
Subject: GS2 Rate Controller pressure transducer
Colorado
I have installed a Raven pressure transducer (422-0000-059)on a sprayer to be used with a GS2 Rate Controller. Rate Controller manual states if a Raven pressure sensor with a 12v power supply is used,
The slope will be 16 mV/psi.
Is this the right slope value and voltage for this transducer?
If I recall right, JD literature states GS2 rate Controllers used pressure sensors with a 5v power supply and output of 0-5v.
Thank you for your help through this process.
