Search Forums | Classifieds (58) | Skins | Language
JD 7410 Clutch engagement question
Jon S
Posted 3/27/2011 10:47 (#1692854)
Subject: JD 7410 Clutch engagement question
PowerQuad transmission. No LHR.
When the tractor sits overnight and is placed into gear for the first time at startup, there is no feathering of the clutch. It's either in or it's out. The second and every subsequent clutch engagement works as it should for the rest of the day...even after shutting the tractor down for an hour or more. The transmission also modulates just fine between forward and reverse without the use of the clutch.
Any ideas?
